按理说是应该8MHz,注释写的16MHz,代码复制也是16MHz
这边问下ST FAE,看怎么回复。
HAL库内:
* @brief This function is used to initialize the HAL Library; it must be the first
* instruction to be executed in the main program (before to call any other
* HAL function), it performs the following:
* Configure the Flash prefetch.
* Configures the SysTick to generate an interrupt each 1 millisecond,
* which is clocked by the HSI (at this stage, the clock is not yet
* configured and thus the system is running from the internal HSI at 16 MHz).
* Set NVIC Group Priority to 4.
* Calls the HAL_MspInit() callback function defined in user file
* "stm32f1xx_hal_msp.c" to do the global low level hardware initialization
* @note SysTick is used as time base for the HAL_Delay() function, the application
* need to ensure that the SysTick time base is always set to 1 millisecond
* to have correct HAL operation.
* @retval HAL status
HAL_StatusTypeDef HAL_Init(void)
这里
有点问题, 我看了下, SYSCLK默认应该是8MHz 才对啊
